Wallet problems
I have the same problem, when I logged into Brave wallet asked me to upgrade, clicked on button, asked for new password, now wallet is showing but only has my Ethereum showing. No other coins showing even when I put in contract addresses. Seem to have lost access to all my tokens funds and staking
make sure your address is the same as you had before. otherwise maybe you needed to import as legacy wallet
It is showing the same account addresses but not showing any of my tokens only ethereum and not connecting to platforms I had coins staked on where I used to connected through metamask symbol to Brave wallet. How do I revert back to the old wallet so I can access my coins and staking. Also I has matic chain and BSC chain and others that had assets also not showing or able to connect. How do I access my tokens and stakings and add the other chains BSC, Polygon/matic and AVAX and others?
Thanks
Go to brave://settings/wallet and switch Default cryptocurrency wallet to Crypto Wallets (Deprecated).
If your account address is same in the new wallet, you will have to add other networks Polygon, BSC etc. to view your tokens. You can add networks here- brave://settings/wallet/networks. You can google some details in the field or use https://chainlist.org/ to directly add networks after connecting your wallet.
I’m trying to connect from the new brave wallet to immutableX and i just can’t. ii have a tons of assent in immutableX and i used to entered with the crypto wallet (deprecated) and now a can’t connect with either one with this message.
Error
Something has gone wrong.
Please check your wallet’s connection and transaction status.
For further assistance please visit our support page.
i already contact immutableX support and the say is your responsibility. This Update and this wallet is horrible. how a get the JSON file of the brave wallet. i successfully migrate to the new one with my 24 -word seed phrase but this same phase open a different wallet address in metamask. i really need to access the immutableX account
We’re working on implementing this which will make it work:
You can use Crypto Wallets again (not compatible with MetaMask though) in brave://settings/wallet set your default wallet to Crypto Wallets (deprecated) until the above is fixed. Sorry for the inconvenience.
Please post new issues as new issues, I’m closing this issue.
V1.35.100 was just released with this fix
