VPN: When opening links from apps, connection sometimes breaks. The problem has existed for several years, but has not yet been resolved
VPN: When opening links from apps, connection sometimes breaks. The problem has existed for several years, but has not yet been resolved.
  1. be on mobile network (not wifi) and have an active VPN Connection
  2. disable adblocker in Brave
  3. close the browser completely via the task manager
  4. open a link from another application
you (sometimes) get an err_internet_disconnected or err_network_changed error
Expected Result:
The page should load without errors
In approx. 2 out of 5 cases
Brave Version(See the About Brave page in the main menu):
1.75.178 Stable; Also tested on the acutal beta and nightly
Yes
Additional information:
Tested with various Android-based devices. Not reproducible on iOS devices.
netlog-network-changes.txt (7.3 KB)
You might
  • free your Android device from any backup/sync chain, while:
  • be sure that you actually exit/quit BB (instead of only, merely closing tabs/windows)
  • clear cache etc. (everything that you can)
  • do 2 complete shutdowns of the device
In other words, try to shake off any setting, site specific setting, etc. that is sticking and effectively causing something like “continuing where you left off.”
May interest:
Thank you very much for your advice @289wk. I have already tried everything you have described, even a new installation of Brave was not successful. The problem has existed for several years and on various end devices.
