the url is missing an “n”
Since i cant find an email to support this to, i’ll post it here
@Fro0ozE Thanks for mentioning. The irony is even in the correction, there is a typo. (^_^) But I do see where the m
in .com
is missing. I’ll make sure to tag @steeven and @Mattches on that so they can try to get it fixed.
Thank you will update
