after updating the application (on my phone) the application could no longer open, I tried many ways and none of them worked. In the end I decided to reinstall it (here begins my big problem) after uninstalling it it works but when I try to synchronize to have all my information, data, history, etc. I can no longer because I get “The code was generated by an outdated version of Brave, first update your other device”. when reinstalling the application I cannot update the “device” to activate synchronization
The reason for this is the sync code changes daily. so you cannot write down the code and expect it to last forever. I do not know how long ago that you did yours. If you are using 24 words then you have an old one and you just need to attach the 25th word which is the one that specifically changes every day. If you were using the 25 word phrase then you will need to forget the last phrase of that and plug-in the newest 25th word.
