Rewards accredit problem
I have been using brave for about 3 months now, on this computer the rewards are accumulated but not credited once a month.
My uphold is verified on March 16, 2021, I use the version of brave Version 1.25.72 Chromium: 91.0.4472.101 (Official Build) (64 bit)
I receive payments only from windows, I don’t receive them in the computer where I use linux “Ubuntu 18.04.5 LTS”.
I don’t use a VPN
I live in a supported region.
I have not manually turned off auto-contribute on my devices
Chrome/91.0.4472.101 Safari/537.36
If you don’t manually turn OFF auto-contribute, you will likely be unknowingly donating BAT back to Brave.
How many Brave profiles/devices have you linked to your Uphold wallet? This includes reinstalling Brave or your OS, resetting or replacing your device, etc.
I ve linked 2 devices auto-contributo is turned off
And you have never linked any others, or reinstalled Brave or your OS, or reset or replaced your device?
No, I only installed it on 2 computers one with windows and it works, the one with linux has problems
Have you tried unlinking and relinking the Brave profile on the Linux computer?
What does your brave://rewards-internals page show for the External wallet information?
ok I send U all information
You have had Brave Rewards on that device in the past? Also, please edit your post above to delete the Wallet payment ID and the Wallet address.
I received them the first month
How exactly does one “unlink and relink the Brave profile”?
And will doing so increment the dreaded “maximum 4 devices”?
Thanks,
John
