I try to login in a website in which I already had loged in before
This means Brave already has the login data (username and password)
This problem is not happening for all websites, but for some. e.q. https://go.readly.com -
If I’m at the website brave the following is happening:
The program suggests a false user name (e-mail address) that does not belong to this website. Sometimes several incorrect login names are suggested.
I then enter the correct login name manually. When I then click in the password field, Brave suddenly recognizes both the login name and the correct password.
If I then search for the website in the password manager, Brave does not find the correct login data for this website.
Everytime I log into these websites the problem occure.
One more excample ist the website https://www.volkswagen.de/de/besitzer-und-nutzer/myvolkswagen.html
Brave should be able to save and find the nlogin data for each website
Brave ist auf dem neuesten Stand
Version 1.68.134 Chromium: 127.0.6533.88 (Offizieller Build) (64-Bit)
best regards
Andreas Schuetz
