Problem - Brave not updating, attempted to download and failed.
How to reproduce - I’d assume just trying to download. Went to brave.com/download. Clicked on link to download Windows 64 bit. Site redirected to laptop-update.brave.com, and received:
If spelling is correct, [try running Windows Network Diagnostics](javascript:diagnoseErrors()).
DNS_PROBE_FINISHED_NXDOMAIN
I can do a “nslookup laptop-updates.brave.com” to get an IP address (151.101.13.32, although I just got 151.101.185.32). Replacing the name with IP gives a domain error:
Fastly error: unknown domain: 151.101.13.32. Please check that this domain has been added to a service.
Details: cache-fra19152-FRA
Tried with both Brave and Chrome. Chrome: 96.0.4664.45, Brave 1.21.76.
Tried for a couple of days with a couple of reboots between. Still no luck…
All I can guess is my ISP doesn’t like the Brave site for whatever reason. Tried through my router and directly through the ISPs router.
AVG. Hadn’t tried it but with AVG down, same problem.
Secure DNS was on, although it had a warning, “Secure DNS may not be available all the time” but same result with it off.
Initially, I was using Chrome for everything. https://brave.com/download will not download for me with either Brave nor Chrome. I figured I could download the installer with Brave, then stop it and load. No luck. No luck with Chrome, either…
Checking the proxy, firewall, and DNS configuration
Running Windows Network Diagnostics
ERR_NAME_NOT_RESOLVED
No proxy. Wowway internet. Have a router between the ISP’s modem and the rest of my equipment. Never spotted anything like this before. Seems to only affect the laptop-updtes.brave.com. Also don’t get the “name not resolved” when comes up with:
The toggle switch itself should be gray in your case if so.
I can’t say for certain that the IP address you’re getting is correct, but I think likely yes, as it is very similar to many other IPs returned for that address.
Can you paste your entire nslookup output?
Also, what if you enable Secure DNS, but use one of the included providers – such as Quad9?
My nslookup output… Now you know my non-conventional home IP range… Change my service provider, and I’m not going to run into my address range matches the modems!
So no matter how I try to get there, I’m getting odd results. Haven’t seen an issue with any other sites…
OK. Interesting. So it looks like your local Windows system has 2 DNS servers configured, the 172.x one shown in your earlier reply as well as the 64.x one seen there. The latter of which looks like it’s your ISP’s, try11-dns1.try.wideopenwest.com.
Not sure if that’s intentional, as your host could use one or the other. Also, not sure if you got those DNS server IPs from a manual configuration on your system, or via DHCP. If the latter, and if this is not your intended configuration, you’d want to change your router config to distribute something else to DHCP clients. But your router itself may very well be using your ISP’s name servers, so all of this could be moot. And I’m not super confident this is really the issue anyway, so maybe we can save that for later if needed.
In the meantime, what do you get back from Resolve-DnsName -Type A laptop-updates.brave.com -Server 64.233.217.2?
And plz repeat the above against the 172.x server, Resolve-DnsName -Type A laptop-updates.brave.com -Server 172.2.37.1.
Even though this does look like a DNS issue we can’t be sure yet, but the above will help us narrow it down.
Ultimately I do feel like we could figure it out with a packet capture (Wireshark) but that takes another degree of familiarity and effort, hopefully something else surfaces by then.
I do find this very odd. My network configuration does NOT have any secondary DNS. All comes from DHCP. According to the router, Wowway has two DNS servers, one you’re quoting 64.233.217.2 and 64.233.217.3.
Not sure what Resolve-DnsName does, but it doesn’t appear to have worked successfully. Looks like neither DNS server would give an answer to laptop-updates.brave.com.
Then how is nslookup coming up with an IP address?
So the router must be passing forward the first WAN DNS server… Not sure why the Resolve-DnsName didn’t come up with an IP address though…
Terry
P.S. I’ve done a bit with Wireshark, so a Wireshark capture is possible although I haven’t ever figured out how to read the gobbledy-gook that comes out of it!
Unclear. I know historically, at least on *nix platforms, the maintainers of nslookup have been trying to deprecate it for eons but it continues because it’s so culturally ingrained.
But if I had to bank on which method duplicates Windows’s actual DNS resolution under the hood, my money would be on PowerShell’s Resolve-DnsName.
Do this at your own risk; but if I were you I would try configuring your router to distribute Google Public DNS (8.8.8.8 and 8.8.4.4) to DHCP clients. And then wait a while, or renew your DHCP lease, but one way or another make sure your Windows system gets the new addresses (verify with Get-DnsClientServerAddress).
And then see what happens with your browser issue.
Using GPDNS may be sub-optimal for other reasons but we can cross that bridge when we get to it.
P.S. While I think we might be uncovering an issue here, I’m still perplexed as to why it failed when you explicitly set Brave to use Quad9. Something there still doesn’t add up.
Could NOT figure out how to configure DNS into my router. Changed my computer’s configuration to use 8.8.8.8 and 8.8.4.4. Also tried using the Secure DNS internal to Brave with the Google option. Think it’s slightly different:
