The 7 Bat Upholds I won in March have not arrived in my wallet. I state this and expect support as needed. And many people continue to have problems with this. No response from the support team. If necessary, I will continue to open this topic every day. @steeven
and that will only slow things down even more! It’s a known issue being investigated and here’s an update from earlier today: April 2022 Ads Payout Issues Update
Payout for Uphold users If you are an Uphold-verified user and did not receive your payout, it is most likely not related to the above payout issue. Uphold users still receive direct deposits, and we did not see any major issues with the direct deposits for the April 2022 ads payout. The most common reason is that your payout was withheld because your Brave Rewards profile is flagged. If you aren’t flagged, it’s also possible that the direct deposit into your Uphold account didn’t make it for some other reason (for example, your Uphold account is restricted, and so the transfer from our Uphold account to yours was blocked). As far as we know, there was no major bug or issue with the payout for Uphold-verified users. Accordingly, any issues payouts to Uphold-verified users would be on a case-by-case basis.
I’ve been a verified uphold wallet user for over 1 year. and i am having this problem. This is the problem I was talking about. @steeven
