Print Dialog on macOS will not allow US letter
Go to any webpage, open Print Dialog via Command-P. It will not show US Letter in the paper size. I can see US Legal and A4, along with many other options, but no US Letter. If I go to the System Dialog instead, US Letter shows up fine, and is in fact the default for the printer.
I have tried re-installing the printer under macOS, no change.
[Version 1.7.92 Chromium: 80.0.3987.163 (Official Build) (64-bit)]
macOS Catalina 10.15.4
Found issue - had to completely remove and then re-install printer driver’s using HP latest. Not a Brave issue.
