@bkwriter,
Would you be willing to download/install the Brave Beta build? I’d like to see if Beta (or any other build) behaves the same way. If so, it likely points to a system problem as @ZerosNOnes is hinting at.
Note that downloading/installing the Beta will not interfere or overwrite any data in your current Brave installation.
OK, downloaded. Looks like I’ve got Brave and Brave Beta. Thought it might overwrite the old program. The idea is to see if the beta acts normally when I start the PC, right?
That is correct – just start browsing as you normally would and see if you can reproduce the crash. If Beta behaves without the same issue, it’s likely isolated to Stable build and we can continue further narrowing it down from there.
If Beta build starts crashing in the same way Stable does, the issue is more likely on the system side of things (or compatibility).
Turned on my PC this morning, Brave/Brave Beta wouldn’t load. Then I tried it in the new Windows profile; both loaded normally. I restarted my PC and both Brave versions loaded in my old profile.
ZerosNOnes offered some suggestions about copying/pasting my old profile into the new profile. I’m going to hold off until I hear from you. Many thanks.
@bkwriter – sounds like you in good hands here w/@ZerosNOnes!
It does seem like the issue is linked to your system profile so I think porting your data from one profile to the other seem a logical next step.
Type “C:\Users\OldProfile” where? I tried all kinds of places. And I tried C:\Users<my profile name> and it didn’t work.
I also searched and found directions for deleting the old user profile via Windows r and then “SystemPropertiesAdvanced” which brought a box of user profiles. I did this in my new profile so I could delete the old one. But the delete button is always greyed out. I even turned my PC off, signed it with the new profile (just in case somehow I wasn’t signed out from the old one) and it was still greyed out.
Then today I turned on my PC, signed in with the old (supposedly corrupt) profile and Brave loaded the first time. Go figure. I’m at the point where I either go through the hassle of setting up the new profile or just giving up and going back to Chrome. I’m leaning toward the latter.
1.) Press the Windows key + R to open the run dialog.
2.) Type in C:\Users into the box and press enter to open the user profile folder containing all of your profiles.
3.) Open your main profile folder.
4.) Click the view tab and uncheck Hidden items
5.) Highlight all of the files and folders and press CTRL+C keys to copy.
6.) Press the Backspace button to go back to the C:\Users folder.
7.) Right click on your New Profile folder (w/e name you gave it) and click paste from the right click menu.
