Need help regarding the BATs I received
Hello @steeven ,
My march/april payout was supposed to be of 5.645 BATs and I did receive 5.635 BATs 9 days ago on 4th of April. I am wondering if that was just a bonus reward or was that my earned BATs because I got that payment even before the payments started rolling out for Uphold (my browser is connected to Uphold)
Uphold Wallet Address: 0xF33F66362EDDeeaEd3eD2DfC95D920a6CC252893
What Operating System and Brave version are you using?
-Yes
  • Don’t remember
-Yes
Are you using a VPN? (yes/no)
-No
-Yes, India.
-Yes
@amitsingh410,
Anyone affected by the payment issue will have received the bonus. If not affected by the payout issue, then they should have received normal payment, which appears to be the situation you’re in.
Thank you.
