Problem: In Vertical Tabs, the Tabs list always hides the vertical tabs menu when I right-click and try to access the menu (change name, change color, or any other actions).
Does anyone have any recommendations that I can implement locally or does this need a ticket/Pr for a fix?
I’ve had this issue ever since I started using Brave, in late 2021, so this has occurred on each of the most recent Release Brave builds for this machine. As for build numbers, I always update to the most recent MacOSX and Brave builds when they come out, so for attempts to reproduce, just use the latest MaxOSX/builds.
Partial workaround. Put vertical tabs into icons only and view/access the rest of the right-click menu div.
Attempts to Fix Today: I spent the last 1.5 hours trying to finally fix this for good, but to no available. I removed Brave from applications, the info in Applications Support/Brave Software
, redownload, reinstall, test by creating a Vertical tabs group and right click. Maybe within a minute of installation, the Brave broswer reverts to the problematic behavior and is no longer fixable. I tried this process probably 5-6 times, along with a laptop restart, before the behavior became → install → issue already there from the beginning of the installation.
I think this is a machine or maybe a M1 Pro specific issue, because my work machine (lets say Machine 2) running a M2 Pro with the latest Brave build release and the same tabs, settings, etc (via sync) on Machine 1 (M1 Pro) has none of these issues.
Tech Specs
MBP 14 2021 w/ M1Pro
MacOSX. Always the latest
Brave. Always the latest
I also have a 30s video showing other attempts to use this. Can if requested
I’ve only seen this reported once in Community
The closest thing I could find on Github was the following
https://github.com/brave/brave-browser/issues/28093
