How to pin frequent websites (not pin tabs)
No issue, just want to know how to pin a web page to BRAVE homepage?
Brave Version( check About Brave): Version 1.5.123 Chromium: 80.0.3987.163 (Official Build) (64-bit)
I’m also looking for that answer.
@farabee @Ief hover the tile on New Tab Page, then pin option will be shown.
Yes. You are correct. But that’s not the answer to my question. I want to pin “pages” to my Brave home page. Not interested in pinned tabs.
Thank you, however.
Then, can you elaborate more about what you mean by “Brave home page”? A screenshot will be really helpful.
Thanks
I’ve wanted to share a screenshot since this question came up. I feel like I’m not using the correct terms.
To me, this is Brave’s home page…pretty picture, clock in the right hand. I want my favorite/used daily sites to appear as these do. However, Brave put these on here, I didn’t. How can I add a site by myself? Also when I move them, I don’t always get what I intended.
I’d like the last icon to be first, followed by asterisk icon, etc.
Thanks for allowing me the opportunity to explain.
Pins on homepage would work great as speed dials on opera for example.
So I joining farabee in this question… she has not been yet fully answered so is it a no? you cant add own pins to homepage and more then 5?
Apologies for really late response @farabee.
So, you referring to Top Sites tiles on New Tab Page. For now you can’t add/edit the tiles manually. Top Sites tiles is populated based on your browsing history.
That’s all I needed to know Thanks eljuno. Sorry I didn’t have the proper vocab to ask the question. “Top Sites tile"
