Briefly describe your issue:
I would like the devices linked to my uphold wallet to be removed so I may relink the ones I still have access to. Some devices I either don’t have or they have been reformatted and thus need to be relinked, however upon trying to link more I receive an error that I have reached the maximum amount.
MS Windows Version 21H2 Build 19044.1466
Brave Version 1.34.80 Chromium: 97.0.4692.71 (Official Build) (64-bit)
Yes
About a month ago, but not all devices on the same day. I do not remember exact dates.
Yes
Are you using a VPN? (yes/no)
No
Yes
Yes
Yes
