Hardware Acceleration problem in OSX 11.2.3
Since the Update to OSX 11.2.3 the hardware acceleration is broken. Images on different sites aren’t visible anymore. The images appears shortly and disappear.
I have tested the last Version of Brave i think this is a problem from the last OSX Update. I have tested Chrome in the last version and there is no problem.
I have removed all extensions with no success. Disabled the Filter with no success. I have tested a lot now.
When i disable the Hardware acceleration everything is great and everything is visible.
This Problem seems to appear only with an external Monitor. With the Macbook only the problem isn’t visible.
