Gas fees, Please help
I have about 100USDC but cant transfer it to any other acc withraw it. It said i needed gas money so i ended up buying some ethereum to pay for the fee but it still says i have insuficient gas. I would be very gratefull if someone could help me
@udatao27 first off, did you buy Ethereum because it said you need it? Guess I’m asking because you haven’t said anything about what network your USDC is on nor which network you bought ETH from.
For example, if your USDC is on Optimism, then your ETH needs to be on Optimism. If you bought ETH on Ethereum, then it would be no good for gas.
So it’s important to pay close attention to which networks your on and what you’re buying to use for gas.
