Hello,
I have a few features for brave team to add:
Work spaces - instead of groups (or add toggle option between groups and work-spaces) allow us to switch different spaces like work, security, gaming, etc. This will help keep tabs area clear. Put work-spaces next to the search bar if it’s possible.
Better Shortcuts - Brave can install PWAs if websites support it. If website doesn’t support it you have create a shortcut but you get an ugly low res icon with brave icon bottom left and it doesn’t get sorted under brave browser apps. Please make shortcuts look and act like PWAs.
Mouse gestures and custom gestures - open new tab, reload tab, etc. Custom mouse gestures to create our own.
Picture in picture button - Some video platforms don’t do PIP and on YT you have to click twice to get PIP which is silly. Add a PIP button in the top centre so all video platforms can have PIP as well a volume control. The seek bar in PIP needs work as well, if you don’t click further back it won’t move or will jump forward.
Auto remove browsing history - option for auto delete history after 1, 3, 6 or 12 months.
Tab location - Add the option to put tabs section at the bottom instead of the top.
Floating panels - add an option for floating panels. Example the sidebar resizes your page, instead let it float above.
One more I can think of, some may say no because it might be bloat but:
- Notes - add notes and let it sync between desktop and mobile.
Thoughts and Thanks
