Crash occurs when using vertical tabs and attempting to pin a tab that's part of a group
When using vertical tabs, attempting to pin a tab that’s part of a tab group will cause the browser to crash.
  1. Ensure that vertical tabs are enabled.
  2. Create a new tab.
  3. Add the tab to a tab group.
  4. Right click on that tab and click on “pin.”
The tab is pinned.
Version 1.68.128 Chromium: 127.0.6533.73 (Official Build) (64-bit)
This only appears to be an issue when vertical tabs are enabled. I can’t seem to reproduce it otherwise.
I second this :point_up_2:! I am having the same problem both in Win 11 and Win 10 with Brave
Version 1.68.131 Chromium: 127.0.6533.73
@steeven @Mattches I was able to replicate this. I was trying to upload and share crash report for you guys, but something screw seems to be happening with that… After crashed, had the following:
But after hit Send Now and exit Brave, it vanishes.
This happens on:
  • Brave Release: Version 1.68.134
  • Brave Beta: Version 1.69.129
  • Brave Nightly: Version 1.70.30
In all cases, it never lets me see the Uploaded Crash Report ID as the crash in the log just vanishes.
Thank you both for reporting — can reproduce and have opened an issue for this here:
