Currently when trying to load a local host react app verified with OKTA I get this error:
Uncaught runtime errors:
ERROR
Could not load PKCE codeVerifier from storage. This may indicate the auth flow has already completed or multiple auth flows are executing concurrently.
AuthSdkError: Could not load PKCE codeVerifier from storage. This may indicate the auth flow has already completed or multiple auth flows are executing concurrently.
at http://localhost:4200/vendor[.]js:328718:271539
at p (XXXX://localhost:4200/vendor[.]js:328718:325682)
at Generator._invoke (XXXX://localhost:4200/vendor[.]js:328718:325435)
at Generator.next (http://localhost:4200/vendor[.]js:328718:326045)
at r (XXXX://localhost:4200/vendor.js:328718:332835)
at u (XXXX://localhost:4200/vendor[.]js:328718:333038)
at XXXX://localhost:4200/vendor[.]js:328718:333097
at new Promise ()
at XXXX://localhost:4200/vendor[.]js:328718:332978
at v (XXXX://localhost:4200/vendor[.]js:328718:272067)
A new private window works fine and a normal window in Chrome also works fine. This issue only seems to be with a normal window in brave. It’s only just started happening. One minuet it was fine, reload page and now we have this error.
I’ve no idea.
NOTE- I’ve changed some of the http to XXXX because it can’t create the topic with all the https in the body of the text.
