Connection Problems to my Uphold Wallet
When i open the page “https://publishers.basicattentiontoken.org/publishers/home” i see this warning note on the left side of the site:
" Your Uphold Wallet
Connection problems"
May anyone help me to fix it or suggest any solutions? Or any ideas at least?
Team is working to fix this issue.
Thanks @YonhPal for the reply.
I have the same problem, even though it was working perfectly and i got my payment on the 8th of March.
are you a fully verified member in uphold? @wael.khuzam
Yes i am, since march 2018
It was connected but now when i log in it flashes “connecting” then it shows “connection problem”.
my problem is solved. try to delete the history. if it does not work disconnect and reconnect. it worked when i reconnect after i disconnect. @wael.khuzam
Thanks @obyzopy, it worked.
