Blocking cookies between sites causes a lot of problems. It would be nice if this setting is turned off by default and the conscious user is enabled to turn it on.
If we clear the history of the site settings, the shield settings are reset. Correct the Brave shield settings so that they are not affected when the history is cleared.
Brave version : [1.2.43 Chromium: 79.0.3945.130 (Official Build) (64-bit) Sürümü]
