Both video lag+slowmotion and audio lag when using hardware-acceleration
The issue I am having is that when using hardware-acceleration, the video decoding is extremely unreliable… On youtube, the video will skip seconds of content and run in slow-motion randomly but consistently throughout the videos I watch.
Some examples of my issues (Please watch the whole video to see the problems):
Broken:
Broken (Private):
Working (Chromium):
The video in my example: https://www.youtube.com/watch?v=E3Q8TOsc5ZU
The issue occurs regardless of shield settings.
No.
No.
Yes, with Chromium 98.0.4758.80, with hardware-acceleration on, it works as expected.
Version 1.35.100 Chromium: 98.0.4758.87 (Official Build) (64-bit)
Fooughhy,
If you are willing to dig and troubleshoot, you might consider using Brave Browser Developer Tools >> Network
You can find that (Developer Tools >> Network) by using the Brave Browser Help menu and within its Search field, type “Developer Tools” (no quotes).
A lot of tips on how to use Developer Tools:
You can set the location for the Developer Tools window, including, detaching the window.
Using Developer Tools >> Network, takes practice.
You will no doubt discover differences (as in, what gets blocked) – between using Brave Browser and Google’s Chrome browser.
