- Android Dark Mode does not work in Brave [Stable]
- It does work on Brave Nigthly
- there is a quick switch missing on main UI to toggle dark/light mode - can it be added in a place eg of Home button?
- changing light/dark mode thru Brave options is very uncomfortable
- even the dark mode works in Nigthly the bottom task bar, wher you have tabs opened is still solid White.
Have you tried:
Settings > Display > Appearance: Automatic
Night mode: Disabled
Brave Shields & Privacy > Private Browsing Only: Enabled
Yes, also on Brave (stable) there is a problem when i want to disable experimental dark mode - when i click turn off this function, brave wants to restart, but after restart this option remains on.
What the design of the dark mode? When it`s activated it should respect system color scheme (light/dark) and when dark mode is set on system, the website also should be rendered in dark mode?
