The top edge of the browser window cannot be used to resize window.
Open Brave desktop
Hover mouse over left, right or bottom edge and mouse pointer changes to the appropriate resize handle/icon as expected.
Move mouse over top edge of window and there is no response.
Brave Version 1.65.114 latest at time of posting
Running on Windows 11 Pro 10.0.22631 Build 22631
Same issue here.
Dragging handles at the bottom edge of Brave Windows are still functioning.
Brave is up to date:
Version 1.65.114 Chromium: 124.0.6367.60 (Official Build) (64-bit)
Windows 11 Pro
Version: 23H2
OS Build: 22631.3520
Windows Feature Experience Pack 1000.22700.1003.0
Same issue here, by the way I am using a 4k screen on my laptop, unsure if that is related. All other edges of the browser window can be dragged, but not the top edge.
Windows 11 Pro
23H2
OS build 22631.3447, Windows Experience pack 1000.22688.1000.0
Brave Version 1.65.114 Chromium: 124.0.6367.60 (Official Build) (64-bit)
Resolution 3840 x 2400
By the way, please allow more icons on the custom home screen for bookmarks… like a cell phone home screen would be ideal. For the life of me I don’t understand why all browsers don’t have this feature… I know so many “old people” who just want their bookmarks and this would help them immensely.
Same issue here on Windows 10, latest release
Team is aware of this bug — have opened an issue for it here:
opened 08:15PM - 18 Apr 24 UTC
bug
OS/Desktop
<!-- Have you searched for similar issues? Before submitting this issue, please … check the open issues and add a note before logging a new issue.
PLEASE USE THE TEMPLATE BELOW TO PROVIDE INFORMATION ABOUT THE ISSUE.
INSUFFICIENT INFO WILL GET THE ISSUE CLOSED. IT WILL ONLY BE REOPENED AFTER SUFFICIENT INFO IS PROVIDED-->
## Description
Resize cursor is not shown while mousing over the on top of the title bar and so unable to resize the window. Users can still resize by either dragging the corners or the bottom of the screen, but they lose the ability to resize the window at the top. Able to resize the window if `Show title bar` is disabled for vertical tabs which is related to https://github.com/brave/brave-browser/issues/30050.
## Steps to Reproduce
1. Install 1.65.114
2. launch Brave
3. minimize the window
4. mouse over the top of the window
## Actual result:
Resize cursor is not shown and hence the unable to resize the window from top
https://github.com/brave/brave-browser/assets/98358127/2816c38b-ad57-4ed2-9e85-5141e0915470
## Expected result:
Users should be able to resize the window from the top
## Reproduces how often:
Easily
## Brave version (brave://version info)
Brave | 1.65.114 Chromium: 124.0.6367.60 (Official Build) (64-bit)
Revision | f1e2cbb65e11340d9040d5ef0b0115c7a5206207
OS | Windows 11 Version 23H2 (Build 22631.3447)
## Version/Channel Information:
- Can you reproduce this issue with the current release? Yes
- Can you reproduce this issue with the beta channel? Yes
- Can you reproduce this issue with the nightly channel? Yes
## Other Additional Information:
- Does the issue resolve itself when disabling Brave Shields?
- Does the issue resolve itself when disabling Brave Rewards?
- Is the issue reproducible on the latest version of Chrome?
## Miscellaneous Information:
@rebron
cc: @Brave-Matt
Awesome! So glad it’s not a new feature
Having same issue with no top-vertical cursor. Hope this is fixed soon.
My Brave is doing the same thing. Ironically, I noticed the same issue with Opera (Chromium) a while back and they now have it resolved.
Thanks for the fix in version 1.65.118
system
Closed
May 25, 2024, 11:01am
10
