Settings page width problem
Problem:
The Settings page has a narrow selection column to the left, and a broad pane of settings values to its right.
I am using Version 1.34.80 Chromium: 97.0.4692.71 (Official Build) (64-bit) on Win11 with a 1920 x 1080 screen. I use the browser at half-width (960 x 1080) which approximates an A4 page view.
In this view, the settings values pane is centred, showing only the first group of options “Get Started”; the selection column is masked off and inaccessible. It only becomes visible at full-screen view.
Question:
Is there a setting to either show ALL settings, as previously, or a horizontal scrollbar to access the selection column?
Alternatively, could the page be made to adjust to the viewport, showing both panes?
KiwiMitch,
Maybe, when you start up Brave Browser, you create a New Window and arrange its size so that you can see the entirety of the Settings:
brave://settings/
. . . and then minimize that window. You can always restore that settings window, later, as you work with other Brave Browser windows.
