So I’ve been using the brave search engine. I’ve noticed some topic results are just as censored as Google. Almost, just like Google in fact. Very disappointed in that. I’ve used two different search engines to compare the results to. Going to have to do better if you want to beat the big tech or you’ll just end up being one of them!
Would you add a screenshot? What results are being censored?
Hi @Scoad21, Welcome to Community!
Thanks for the feedback.
Please note if you also get a prompt from Brave Search to send feedback. Please also send feedback there.
Also, If you got to Brave Search Settings, check to see if you have Google fallback mixing
enabled. If so, you can disable it.
