Rewards previously enabled and earned - now not able to view Rewards centre / appears not enabled
Briefly describe your issue:
Previously enabled Brave Rewards and have been receiving rewards for several months. Claimed rewards today which appeared to work fine. Created Brave Wallet with the intention of withdrawing BAT rewards to Brave Wallet. Went to verify browser wallet by clicking on the ‘unverified button’. This then takes me to the Brave Rewards Tab, which has the ‘Start using Brave Rewards’ page, even though I’m already using Brave rewards. Also, I’m now not able to view the ‘ads’ settings.
Please advise how I can fix this to get the Brave Browser wallet verified so that I can withdraw rewards.
What Operating System and Brave version are you using (Menu --> About Brave)? Windows 10
Version 1.45.123 Chromium: 107.0.5304.110 (Official Build 64 Bit)
No.
No
Yes
Are you using a VPN? (yes/no)
No
Yes
N/A
No
For info, despite receiving rewards/ads and having previously enabled rewards, in settings, Brave says that rewards are disabled
Hello,
This is a known issue and expected to be resolved with the latest update: https://github.com/brave/brave-browser/issues/26484
Thanks!
Thanks for the response, look forward to the update.
