Hello everyone, as the title says, I did not receive my January bats (2,123 BAT), and I do not know how to claim it because February bats have passed and now March has started.
In December I entered this and received the payment.
If someone can give me a solution I would be very grateful.
@Maurin99 Hi
Do you still have an issue? Unfortunately, if you do, there just isn’t enough information to help. Can you please answer the following questions from the Rewards Support template?
Please ensure that you’ve read through the following topics/pages thoroughly before opening a topic as your question may have already been answered:
- How do I opt into Brave Ads?
- Why am I not seeing Brave Ads?
- Windows 10 Ads Troubleshooting
- Rewards FAQ
Briefly describe your issue:
What Operating System and Brave version are you using ( Menu --> About Brave
[Note: use brave://version and copy/paste first three lines to get OS & Brave version]
Are you using a VPN? (yes/no)
