Ongoing problems with Metamask (yes I disabled Brave Wallet in settings)
Whenever I want to use a dapp and select Metamask nothing happens.
Works fine in Chrome and started not working when you shipped Brave Crypto Wallet.
Go to https://synthetix.exchange/
Select Metamask
Should open a Metamask dialog
All the time
[Version 1.4.95 Chromium: 80.0.3987.122 (Official Build) (64-bit)]
You can select which provider you want to use via this infobar for a new install:
You can also change it at any time here in settings:
Let me know if you have any issues. Thanks!
