Not receiving ads from Brave
@Arkearn,
What region are you located in?
I am located in india.
yeah in my case there only a few ads since 1st july compared with months ago, it happening in all brave browser in my home and office
For those of you who were not getting ads, was very likely due to this:
@Mattches, does the same explanation apply to Argentina? In my case, I’m using Brave on Windows 10 64 bit.
hi, im having the same problem, also from windows 10 64 bit.
I am in Argentina I have the same problem ads do not appear on windows 7 and on android 7 cell phones
Same problem in Spain. For several days that ads have not reached either the PC or Android. Can you tell us why ads have stopped coming? I have talked to many users and they have the same problem. No one is receiving anything.
Hello, I have the same problem. I can’t see ads from July 1st. I am a Windows 10 64 bit user.
@ensaladilla que vos te quejes que no te lleguen anuncios es el colmo jajajaja tu sabes que yo se que tu sabes que yo se
 igualmente son unos miserables dando token BAT por ads y las diferencias que hacen con los paises en el reparto, se supone que deberia ser igual para todos, esa es la utopia del proyecto, asi que sinverguenzon yo te agradezco el dato. boton! xD
Same here, from MĂ©xico on android
I’m having the same issue in both Android and windows. Funny enough, after my BAT was restored after the last bug where it all disappeared, I now can’t get any ads.
As for windows, I’ve never received any ad notifications.
Hi, I tried to do that, but Pastebin Page do not allow me to create the file ÂŽcause the size.
hello Brave,
i am from USA
I have installed brave browser on 9th july 2020 but till now not received any single ad.
Windows focus assist setting is off, notifications setting is on and brave is listed.
Have tried uninstalling and reinstalled (with copying my default folder back over)
Brave Rewards and ads section both enabled.
Notifications do work as per this website: https://www.bennish.net/web-notifications.html
Version 1.11.97 Chromium: 84.0.4147.89 (Official Build) (64-bit)
i DM you my full log from brave://rewards-internals so please check it.
pudiste solucionarlo? yo tambien hace dias que ninguna publicidad lpm
no, hoy me slio un anuncio en android 7, casi me desmayo jajajaja y en windows 7 nada ayer creo que un solo anuncio que se les debe haber escapado xD Adios a mis referidos, gracias brave :unamused:
For users still encountering this issue, please send me the following information via DM – follow instructions exactly.
If you’re not seeing ads while using Desktop please the following:
  1. In your browser, go to your brave://rewards-internals page (type it into the address bar) and click the Logs tab.
  2. On the right side of the page, select Download full log – it will download a .txt file with some Rewards data in it.
  3. PLEASE rename the file from the default – change the name to [YOUR USER NAME]_Logs. It will help support team stay organized and not lose users info in the shuffle of things.
  4. Send a Direct message to me here on Community with the subject line [YOUR USER NAME]_Logs, and attach the logs text file you downloaded to it.
If you’re not seeing ads on Android:
  1. In your Brave app, go to Menu --> Settings --> About Brave
  2. Tap on the Application version 7 times to enable Developer options, which will appear in Settings beneath the Downloads folder.
  3. Now, go to Settings --> Developer options --> Rewards Debug --> Export Rewards Database
  4. Save the file, then open a DM here on Community, include the subject line `[YOUR USER NAME]_Logs, with me and attach the downloaded file to the message.
Note: Your rewards-internals/Debug information is sensitive/private and should not be made public. Please only send this information to official Brave team members via private message – do not post it publicly on the forum.
Thank you.
the same problem on pc and android
Hi,
I am from spain and i have the last version of brave.
What is happening?
regards
Hay manera de poder traducir incluso estas paginas de Brave al español???
Soy de Argentina, tengo creo todo configurado correctamente pero hace dĂ­as no estoy recibiendo notifiaciones ni sumando BAT, anteriormente lo hacĂ­a, por mas que tengo 5 notificaciones por hora nunca me ha llegado mas de 2 o 3 al dĂ­a y pasando varias horas navegando.
Tengo configurado para que no haga la contribuciĂłn automatica, que me muestre 5 anuncios por hora y nunca he recibido esa cantidad de anuncios aun estando navegando por horas creo nunca haber recibido esa cantidad en todo un dĂ­a.
