did anyone know why this is happening, brave stopped working on x.com stuck on loading ? in chrome working well trying everyhing din’t work , it’s work for few min after clear all data but for couple minute only then started like that again after couple minute, it’s very tired everyime like this need to delete all app data i need to relogin to some sites again even i try to put down on the brave shield still same tho …
Maybe clear the cookies/cache? brave://settings/clearBrowserData
Then re-login.
still same bruh keep like that idk why
Maybe because of
Seeing that icon on your browser means you’re using extensions. The assumption would be that whatever you have running is causing problems.
You could of course test this theory by logging in on a private window (assuming you haven’t enabled extensions to be allowed to run in private) and/or creating a new browser profile.
