Macbook Pro (14", M1 Pro) Overheating
Hi! For some reason my Macbook runs very hot within a few minutes even though only a few tabs are opened (like 1-4). It didn’t happen before but now the browser overheats my Macbook. :cry:
Hi
  1. Disable hardware acceleration
  2. Clear Browsing history
  3. Try disabling extensions
Can you send a screenshot of Brave processes?
Hello @zeeeeeeya, thanks for bringing this to our attention. If the issue persists can you try by disabling cookies and cache maybe there is too much browser data accumulated. Do you have any other applications open while you are using the browser?
