Using bookmarks via the Brave widget, Brave intermittently freezes when opening a bookmark link. Brave will freeze sometimes for 5 to 10 seconds then unfreeze. It will then occasionally freeze again during the same session. Sometimes it will freeze for longer and can only be resolved by ending the process completely.
Opening bookmark link via widget and scrolling through resulting website
The issue does not occur consistently
Issue does not occur with other chromium browsers
Brave 1.16.70 Chromium 86.0.4140.111
Mobile Device details
Samsung Galaxy Note 8 SM-N950F
@Supremocoffee,
Can you test and see if other bookmarked sites open with the same issue? Or, you can test by adding this site (community.brave.com) as a bookmark, opening it and noting whether or not you get the same behavior.
So I have tried to get the issue to occur by browsing community.brave for 5 to 10min but the issue did not occur again. I saved the bookmark, browsed several posts, closed the app, restarted device, repeated the process by opening community.brave from the bookmark widget and so far no freeze on this site. 5 mins prior I was browsing newshub.co.nz and it did freeze so could this simply be site related?
@Supremocoffee,
It very well may be. I would test against a few other sites – can make them easy/common ones like wikipedia.com, brave.com, wired.com (for example) and test the results. If none of those sites exhibit that behavior then it’s very likely specific to that site.
