Hi, I love brave browser and i’ve been used it for 3 month on my pc and my phone and everything is fine but i have two problems.
When i go to google earth and still loading and i turn shield off and still loading but i had uninstall it and then re-install again but still loading again.
When i click upper right corner and then click more tools and click create shortcut and i open it but it’s not opening, i did uninstall it and re-install but still not opening.
What should i do?
I hope you fix it as possible as soon.
Thank you for reading.
iznai
June 6, 2019, 8:56am
3
@Mattches for assistance here.
Try to change UserAgent (Google has an extension for Chrome ).
Sometimes it could help.
Hi, it’s not working for me, i did try for opera vs firefox and other in menu but not working at all, it says you must download chrome.
What about Shields? Did you try to turn it off?
@AlexP5 ,
This is due to us blocking chrome://pnacl/
(Portable Native Client) which Google Earth uses:
Description
The official Brave build misses the Portable Native Client (PNaCl), which, for example, is used by the google earth studio.
Steps to...
webcompat
wontfix
While it’s currently marked as wontfix
, its mentioned in the comments that PNaCl
is being depreciated anyway so we’ll likely see this fixed in a chromium bump down the line. Appreciate your patience.
Don’t working yet and it says Google Earth isn’t supported by your browser and Try download google chrome.
Have you read what i said about other problem, create shortcut?
@AlexP5 ,
The Google Earth situation was answered to in my previous response:
@AlexP5 ,
This is due to us blocking chrome://pnacl/ (Portable Native Client) which Google Earth uses:
While it’s currently marked as wontfix, its mentioned in the comments that PNaCl is being depreciated anyway so we’ll likely see this fixed in a chromium bump down the line. Appreciate your patience.
The issue with shortcuts created this way – also referred to as Progressive Web Apps – is known and has a fix applied moving down the pipeline:
opened 04:15AM - 16 Mar 19 UTC
closed 03:48PM - 31 May 19 UTC
crash
OS/macOS
QA Pass-macOS
priority/P2
QA/Yes
release-notes/include
QA/Test-Plan-Specified
regression
## Description
Facing problems with creating PWA by using the _Create Shortcut… _ option (with or without _Open as window_ ) in the _More Tools group_ under the _Contorl and Customize Brave_ section. On creating a shortcut, it would create a shortcut on the Desktop. However on clicking the shortcut the PWA won't open and would load for ever
## Potential work-around
See https://github.com/brave/brave-browser/issues/3750#issuecomment-480103072
## Test plan / Steps to Reproduce
1. Open any website say brave.com
2. Click the _Create Shortcut_ option (with or without _Open as window_ ) in the _More Tools group_ under the _Contorl and Customize Brave_ section (the hamburger icon)
3. Close Brave and click the Brave website shortcut (Secure, Fast & Private Web Browser wi.._)
## Actual result:
It would take forever to load
## Expected result:
It should open up as a window or a tab
## Reproduces how often:
Easily reproduced
## Brave version (brave://version info)
**Brave** 0.61.51 Chromium: 73.0.3683.75 (Official Build) (64-bit)
**Revision** 909ee014fcea6828f9a610e6716145bc0b3ebf4a-refs/branch-heads/3683@{#803}
**OS** Windows 10 OS Build 17763.379
**JavaScript** V8 7.3.492.22
**Flash** (Disabled)
**User Agent** Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/73.0.3683.75 Safari/537.36
**Command Line** "C:\Program Files (x86)\BraveSoftware\Brave-Browser\Application\brave.exe" --enable-dom-distiller --disable-domain-reliability --disable-chrome-google-url-tracking-client --no-pings --enable-features=NewExtensionUpdaterService,DesktopPWAWindowing,fill-on-account-select --disable-features=AutofillServerCommunication,DefaultEnableOopRasterization,AudioServiceOutOfProcess,AutofillSaveCardSignInAfterLocalSave,UnifiedConsent,SharedArrayBuffer --flag-switches-begin --flag-switches-end
**Executable Path** C:\Program Files (x86)\BraveSoftware\Brave-Browser\Application\brave.exe
**Profile Path** C:\Users\gauth\AppData\Local\BraveSoftware\Brave-Browser\User Data\Default
**Variations** c134752e-f685ead3
2c707b42-dcf7018a
411b6d4e-3f4a17df
d01ab0d3-5ac8943
1a0d11d4-2f9febdf
66df3e9d-a85d0b2f
4b8c3f4-3f4a17df
b7e2524c-c92d551c
411c711e-3f4a17df
b3888d8d-afba0f91
8982496f-3f4a17df
61832c80-3f4a17df
cc20827f-77c422c
2db4845-ace4e138
74785582-3f4a17df
241fff6c-ddf20878
9853922b-3f4a17df
9def365c-3f4a17df
2342e907-3f4a17df
9ca1387e-3f4a17df
1c752ce9-1c752ce9
41e765a5-3f4a17df
ab3d6cfd-3f4a17df
776de70c-e0278d3d
ed9149a9-3f4a17df
a5cb8590-3f4a17df
34d450b1-3f4a17df
6c6c4f61-3f4a17df
76b48ab8-d4bd105c
c70841c8-a2567007
14bdbe54-e8c7a65b
d8343fa3-3f4a17df
b517d646-3f4a17df
8ee5ed19-c3125ea2
74658432-fa79b94c
f978f5fa-3f4a17df
c36cdb78-3f4a17df
9e201a2b-3f4a17df
27212adc-27212adc
591576c8-3f4a17df
5274eb09-3f4a17df
36115667-3f4a17df
ceff87ec-3f4a17df
44827ee5-3f4a17df
8ca44045-3f4a17df
3f79ac13-3d47f4f4
8f1e27f-3f4a17df
77bbdddc-3f4a17df
5485fc4d-3f4a17df
de47491b-3f4a17df
9b4c4257-3f4a17df
8fa604e0-ace4e138
43f62d3b-3f4a17df
4ae380f4-3f4a17df
9e5c75f1-30e1b12b
2594bdf4-3f4a17df
6fa07eb4-7282ca76
2981bcb4-3f4a17df
5139837c-3f4a17df
4934552d-3f4a17df
7f8176d9-3f4a17df
23a898eb-fc93cf74
7a5ba892-3f4a17df
d1cd70a5-80f9a33e
4ea303a6-3f4a17df
ac8d4708-e340be04
b19465ab-b19465ab
6e6e0c7e-3f17a7d8
95876445-2b71ffe4
2b33233e-881ca6c9
b363a81f-3f4a17df
4da5ae82-3f4a17df
56302f8c-2f882e70
dc5b1f29-dc5b1f29
bbc5c1b-3f4a17df
cc54eb06-803f8fc4
b2612322-8a9180b2
cac0a91c-3f4a17df
cec9a952-9a6c5085
f56e0452-3f4a17df
8576baf1-3f4a17df
f3ea30a0-3f4a17df
3038aa2e-3f4a17df
d00fcbde-3f4a17df
9a2f4e5b-4bc735ae
1354da85-f1a864dc
6844d8aa-669a04e0
494d8760-3f4a17df
f9e5da91-508355f5
fcdd9ed9-fcdd9ed9
3a4029d-d7f231f3
b0ea13bc-3f4a17df
3a8217c1-38848f64
94e68624-803f8fc4
cc73f8a1-3f4a17df
b4e8892d-a2d707c6
10a311eb-10a311eb
8834fcca-3f4a17df
6204e469-3f4a17df
### Website problems only:
- Does the issue resolve itself when disabling Brave Shields?
No the issue persists even if the shields are disabled
- Is the issue reproducible on the latest version of Chrome?
No it works properly on chrome
### Additional Information
Would update the issue when it's working.
You should see this resolved in the v0.66x releases.
AlexP5
June 6, 2019, 7:51pm
10
Thank you for your reply,
I’m reading what you said about google earth so i got it and yes, i do changed it " chrome_proxy.exe to brave.exe " but i just want this problem to get fixed it and it would be great
system
Closed
August 5, 2019, 7:51pm
11
