I made 2 transfers from Uphold to my brave wallet (eth and MATIC if that matters) 2 days ago, but they never appeared in my wallet.
I checked with Uphold and they can confirm that the transactions were completed so it has to be something on this side.
I’ll need some help to troubleshoot this issue.
I did this all on my phone (pixel 7 pro android 14).
The eth transfer does show up completed on etherscan & it also shows that my wallet is holding the MATIC as well, however they don’t appear in my wallet.
Yes, both assets are set to visible yet they neither show that I received anything at all.
I double checked with Uphold & their was no mistakes on their end, it was sent to my wallet but nothing is showing up.
@chay_baku and anyone else, I hope you’re cautious and did not click on the link provided by Terfgy. They seem to be a scam account. There is no live chat for Brave. Please be patient while @Evan123 should follow up with you again. If you clicked on the link and provided any information, then they likely will have taken all your cryptocurrency or will use that information for profit.
Minhas transferências para contas externas TB não foram descontadas do meu saldo nem apareceram nas respectivas contas. Mostra transação aceita, enviada, mas não foi realizada. Parece que a carteira não funciona. A transação não aparece na block. Não sei como resolver.
@chay_baku yeah, I had flagged it right away and admins removed the account. But I gave warning just in case you receive emails updates to replies or had checked in before they removed, just to urge caution.
I see @Evan123 wasn’t able to stop by to help today. I’m going to tag in @steeven and @Mattches just to try to make sure eyes are on your issue, as you have been trying to get help for around 3 weeks now.
Some quick questions:
Let me ask some questions. Overall this is just reconfirming things you have said. Sorry to try to ask you to repeat, but want to make sure everyone is on the same page. And please, do make sure to take a second look back at things yourself before responding just to make sure. Thanks
You are saying both ETH and MATIC were sent to your Wallet and isn’t showing, right?
And both of these were done on Ethereum and not on Optimism or some other blockchain, right?
You double checked that the tokens for the right network were visible? For example, you see three different MATIC listed below. Only one of them is visible for me, and it’s the one on Polygon. I would have had to add + the Ethereum or Solana ones.:
You double checked the address for the account(s) in your Wallet and they are the exact same as you see in the blockchain explorers where it shows the transaction complete and an existing balance?
