Grey background overlay on screen.
When I open some web pages, Brave creates a semi-transparent grey overlay shade over the entire page. The page is still legible, but there is no pop-up dialogue or anything that I could click to remove the shade.
I found an earlier report of the problem where the person noted that this can be solved by disabling hardware acceleration(which now is graphics acceleration) but that didn’t work.
Brave Browser version
1.71.123
Computing Device
Laptop
Computing Device Operating system
windows
Does your issue occur at all websites or just some?
some
@hema just a quick FYI, when you create a topic there is a template that gets generated. When you chose this category, it should have been template like below:
Does the ad appear when using a Private window as well? (yes/no)
What OS are you using when you see the ad?
The reason why I’m mentioning this is it seems you deleted it and did not provide the details. One of the important parts of this was that it asks you if it works with Shields off. In testing, the answer to that would be yes (though depending on what you’ve done, might have to clear cookies for the site first).
The gray overlay that appears on websites tends to be because of the cookie banner they have, which Brave blocks by default. Some websites try to force users to interact with it. Turning off Shields and then going to the site would result in seeing the below:
Then whether you Reject All or Accept All, it loads and can be used as normal. You could even activate Shields once again after. This shouldn’t be an issue and will be something that @fanboynz or others will adjust the Shields filters for here in the future, but at least is an explanation of what’s going on.
@hema not really. It’s the website trying to force people to accept cookies. If you automatically hide/dismiss the prompt, then they block access to their website. The default behavior in Shields is to block these prompts, as often they don’t respect user choice and will use it to grant themselves the ability to invade your privacy.
That means the issue is/was happening because of the way the website is coded. Specifically is the website trying to track users. I mean, if you disable protections and let them track you (invade your privacy), then it works just fine. But still would say it’s website issue more than I would browser behavior.
