Briefly describe your issue:
I have stopped receiving Ads from past 2 months for a user profile that is connected to my Uphold Account don’t know why. My Estimated rewards pending are also stuck and they didn’t got collected in the uphold account for 2 months now.
Where can I see which 4 Brave Profile are contributing to my Uphold Account, as currently I don’t know and want to know so that I can use only those 4 Profile’s.
Also why my next payment date is 6th July?
Windows 10 Home OS build 19042.985
Version 1.24.85 Chromium: 90.0.4430.212 (Official Build) (64-bit)
Yes
18/09/2020
Yes
Are you using a VPN? (yes/no)
No
Yes
Its is a Windows 10 PC
Yes
