Briefly describe your issue:
Recently I got a new laptop and reset my old one. When I tried to verify my wallet with Uphold on my new laptop, I got an error saying that the device limit was reached. Can Support please help me remove the now-inactive device so I can start using my new active one?
Version 1.30.87 Chromium: 94.0.4606.71 (Official Build) (x86_64)
No, not on the newly active laptop.
N/A
Not on the newly active laptop. My other devices (which are verified with Uphold) are able to receive payments.
Are you using a VPN? (yes/no)
No
Yes
Yes
Yes
