Desktop Site Issue
Description of the issue: When I click the “desktop site” button, it just adjusts the mobile version of the site to the device’s aspect ratio instead of actually loading the desktop version.
Go to any mobile site and click the “desktop site”: button
Will appear to be a blown up version of the mobile site and the check box won’t be checked.
Brave Version( check About Brave): 1.16.68
Mobile Device details
Android 10
SM-G965U
Build 190711.020
Additional Information
Same result when desktop site is chosen as the default view in “site settings”
I having same issue… Hiaz…
After some experimentation, I’ve found that there’s an issue with the chromium version. The issue happens on both stable and beta, but nightly, which has a different chromium version, is fine.
Update: Problem solved for me after update to version 1.16.70
