Brave microphone problems?
Why does brave deny access to all my sites using my microphone, despite me clicking ‘allow’?
Could you try in a private window?
Does not work, still.
Hello @Samue1
Thank you for reaching out and I’m sorry to hear you are going through this. First, can you tell me what version/build of brave you’re using?
Be waiting for your response!
Version 1.47.186 Chromium: 109.0.5414.119 (Official Build) (64-bit)
@Samue1 Let me just get info and have you test some things here.
  1. What OS are you using (for example, Windows 11, Android 12, etc)
  2. Are you saying this happens on all websites?
  3. Do you get any errors shown?
  4. Does the issue persist if you turn off Shields?
  5. Assuming you’re on a desktop, can you go to Create a new profile from your hamburger menu (three lines on top right) and test if the issue occurs in the new profile? (make sure not to add any extensions or anything, just try the new profile with everything at default)
  1. windows 10
    2.yes
    3.no
    4.i have
Hi @Samue1
Thanks for your reply we appreciate the details. As @Saoiray mentioned, could you kindly use a fresh profile, to do this, select ☰ --› Create a New Profile. (make sure not to add any extensions)
Let us know if that helps!
