Brave fonts are not changing even when I disable hardware acceleration. Please help; this destroys the user experience and needs a fix. Thank You.
Hello @AstroTV, thank you for bringing this to our attention. What kind of device and OS are you using? Did you update to the latest version? Have you tried deleting your cookies and cache? By any chance are you using any extensions? Does the same issue happen in a private window? Let us know this information. Regards.
I am running Windows 11 version 21 and have many extensions and also doesn’t work in a private window aswell.
try going to brave://flags > Search 'Vulkan' > Disable Vulkan > Retest
Let us know if that helps. Regards.
Vulkan doesn’t come up for some reason
Did you type Vulkan on the search bar?
Yes I did shall I send a picture?
I am on desktop aswell
Please share the screenshot so we can further investigate the issue. Thanks in advance.
