Brave is draining the battery of my brand new MacBook Pro. When using safari, I get 7-10 hours of battery, but every time I use Brave I get less than 3 hours. You guys should really work on something, I currently have no other option than switch away from your great browser. Shame that you are losing customers on such a simple thing to fix… Hope to hear from you soon!
Use brave (latest version) on macOS Catalina (latest version)
And nope, it started two months ago (when I got my first Mac). I think I used the version 1.0.0 until recently and it was using battery way too much as well.
Hey @steeven, I tried your suggestions but didn’t changwe a thing…
Brave needs to fix this issue really quickly because it’s not normal. Might have to switch to Safari if that keeps going!
hey @K3V
im using the brave browser for a week now hadnt notices any issues on my macbook air
keep in mind i keep multiple tabs open when i close the browser, there is maybe a solution for your problem maybe you tried it but go to the settings and turn off the first option it displays that continue where you left off i think that is using the ram to store the data temporarily but try it and see if it works… (:
Unfortunately I can confirm same behavior. Mac Catalina 10.15.1, with latest arable brave release .
MacBook Pro Retina late 2013 with Brand new battery (3 cycles). After closing the lis on 100% worked up with 78%. Activity monitor for the last 12 hours shows the majority of used battery is Brave.
