Hi, For the last few days Bitwarden has been warning me that the extension is corrupt and needs to be repaired. But even when I say repair, it doesn’t fix it. I’ve uninstalled and reinstalled, but no change.
Thanks for your help.
What OS and Brave version are you experiencing this on? Do you see the issue when attempting to install on a new profile? Menu → More Tools → Add New Profile
Hello,
Brave version is as follows;
Windows Version is as follows;
It gives the same error when I add a new profile.
Thank you.
I’ve the same problem!
Hey,
I’m still having the same issue. I completely uninstalled Brave and tried again, but I got the same result. The “Dark Reader” plugin doesn’t work either. It also stopped working on my other computer.
I’m waiting for your help.
Hello,
It was fixed when I changed the Brave language from Turkish to English. The problem seems to be the language.
Teşekkürler mstkyldz
