I need to allow certain websites and can’t believe how difficult it is. I thought if I clicked on the padlock icon to the left of the site, I had the option to allow, but I don’t, UNLESS I’m not seeing it.
I found solutions up to a point on Google and in the Brave community. I copied and pasted below what worked up to a point.
I need the steps of WHAT TO DO NEXT because there are a lot of options under “permissions.”
OR If someone knows of an easier way to allow the site, that would be great.
Change settings for a specific site
You can allow or block permissions for a specific site. The site will use its settings instead of the default settings.
- On your computer, open Brave.
- Go to a website.
- To the left of the web address, click the icon you see: Secure
, Not secure
, or Dangerous
- Click Site settings.
- Change a permission setting. Your changes will automatically save.
NOW WHAT DO I DO BECAUSE THERE ARE A LO OF OPTIONS UNDER PERMISSIONS.
thank you.
