os win 11 64 bit
not reciving rewards
Hello @adityasingxh ,
Like shown in the screenshot, Ads rewards will be paid once a month and the next payout will start at January 7th (may take few days to finish the process).
Thanks
I think u are getting confused
0.00 shows Your overall balance that was decided after the last payouts
look on the other the Estimated Earning it shows that what u will recieve for the ads this month it will be added to ur balance once the payout period completes
and only after that it will show in the rewards Summary
Also look at the Ads section it showing that u recieved 53 ads this month and is also showing that ur current earning for the ads u recieved is 0.267 BAT
Hope u get ur solution
@Iamme is right @adityasingxh .
0.00 is your current Rewards balance. And 0.267 is your estimation that will be paid in the next payout (start at 8th of each month); you’ll see the claim notification to claim your Rewards.
Thanks
