This issue can be fixed by telling me what to do to permanently disable Private windows in Regedit(windows key+R)
1.I’m totally addicted to porn and get rid of it.
2.So, I know how to disable incognito in chrome using regedit. For ex: Going to HKEY_LOCAL_MACHINE and then Policies and BraveSoftware and Brave and something more.
3.I don’t what to do in the last few steps and my device has Windows 7 and 32-bit operating system.
PLEASE BRAVE PEOPLE HELP ME
Expected result:Just to tell me what to change so I can never open Private Tab again by pressing ctrl+shift+N.
Probably, there are some other things that you can choose to watch , which you still love them as mush as you love porn, try to focus onto them or just make some research upon the things which are your goals in life , go for them and watch them on you tube, they will slowly get ride of this lusts and finally forget about porn or just watch some powerful pastors from you tube, you will be delivered as I can see you need a deliverance, I think this is enough for you.
