Hi, when trying to print a PDF using the integrated “Print PDF” button in Xero, Brave attempts to save the PDF in a folder on the Mac, if the file is saved Brave then proceeds to open the PDF in a new tab where it can be physically printed. If I want to simply print the PDF without saving it first, there doesn’t seem to be a work around for this. I have togged the PDF settings in Brave but this has made no difference, can anyone help with this please?
Hi
Try
command+P (pdf should be open)
and/or enable Open PDFs in Brave@ brave://settings/content/pdfDocuments
Hi,
Thanks for the reply. command+P is a workaround without all the information but doesn’t print the actual PDF…
