webpage loads in a way where color blocks show and images won’t show
ANY WEBSITE
YES
NO
NO
YES
Brave version (check About Brave
V 1.46.144
Hello @kny
Thank you for reaching us and I’m sorry to hear you are going through this. Could you kindly clear your browsing data, which you can do at brave://settings/clearBrowserData
If clearing browsing data doesn’t resolve the issue, you could test those websites using a fresh user profile. There is an alternative to the fresh user profile - testing in a private window with all extensions disabled.
Let me know if that works!
Thank you for answering! This is how the browser looks after clearing browser data, fresh profile, no extensions, and reinstalling brave. safari displays normally.
Hi again @kny
Could you please try installing the Beta or Nightly version of Brave to see if the issue persist on those versions?
Be waiting for your response.
Beta version is working properly, thank you!
Hey @kny
My pleasure! I’m happy that for now the issue is solved, if you have any additional question or the issue comes back let us know! Have a great day!
