Using 1Hosts Pro, wired bug appeared
I am using adblock syntax of 1Hosts Pro and youtu.be is being blocked, but the blocklist do not have any rule related to it, I know this is cause by 1Host Pro because after removed the blocklist the issue disappeared.
https://youtu.be/
1Hosts Pro blocklist : https://o0.pages.dev/Pro/adblock.txt
Screenshot of the ad as it appears in Brave:
no
yes
Does the ad appear when using a Private window as well? (yes/no)
yes
What OS are you using when you see the ad?
Android 10
Brave 1.59.120, Chromium 118.0.5993.88
