My company uses Atlassian Confluence to document our work.
We use the Gliffy addon to creat diagrams and infografics etc.
In Gliffy diagrams it is not possible to select entities by clicking on them.
It is only possible to select entities via area select.
Entities with descriptions can be selected by clicking on the description.
- using Brave open confluence
- Create a Gliffy diagram
- Add a straight line to the diagram
- Click anywhere to remove selection of the line
- Click on the line to edit it (change dimensions, color, …)
Line is not selected
(no arrow selected)
Line should be selected for editing.
(image taken in Chrome).
Every time.
page in the main menu):
OS: Catalina version 10.15.1 (19B88)
Brave version: Version 1.0.1 Chromium: 78.0.3904.108 (Official Build) (64-bit)
I’m reporting this here because it works in Chrome. As this is the same engine under the hood I assume it has something to do with how Brave deals with JavaScript?!
